11-01-2023 03:31 AM - last edited on 08-04-2024 07:49 AM by James_C
I bought canon lid 400.
I cannot scan at 4800x4800 dpi.
OS : Windows 10
[Personal contact information removed to protect privacy.]
11-03-2023 01:26 PM
Hi taylanguney,
When using the IJ Scan Utility, to scan at a higher DPI, please use the ScanGear button.
Please follow these steps:
1. Open the IJ Scan Utility.
2. Click the ScanGear button.
3. Click the Advanced Mode tab in the upper right.
4. Select your desired resolution from the Output Resolution drop down. If your desired resolution is not listed, manually enter a value within the range of 25 dpi to 19200 dpi (in 1 dpi increments).
More information regarding Output Settings can be found in the manual, here:
https://ij.manual.canon/ij/webmanual/ScanGear/W/MFP/20.0/EN/SG/sg-927.html
11-03-2023 04:15 PM
Hi taylanguney,
1. Please open the IJ Scan Utility.
2. Click the Settings button in the lower right corner.
3. Click on ScanGear at the bottom of the left side.
4. On the right, place a check mark in the box next to Enable large image scans.
5. Click OK.
6. Back in the IJ Scan Utility, click the ScanGear button and perform a scan.
11-01-2023 08:06 AM
Thanks for joining the conversation, taylanguney!
So that the Community can help you better, please let us know if you're getting any error messages when you try to scan at 4800 dpi and what those messages say. That, and any other details you'd like to give will help the Community better understand your issue!
Thanks and have a great day!
11-01-2023 12:25 PM
my operating system : Windows 10
The software I downloaded :https://www.canon-europe.com/support/consumer/products/scanners/canoscan/lide-series/canoscan-lide-4...
The software I installed : CanoScan LiDE 400 Full Driver & Software Package (Windows)
dpi highest 600 :
No 4800x4800 dpi scanning, I checked everywhere
11-03-2023 01:26 PM
Hi taylanguney,
11-03-2023 03:50 PM
1200 dpi ok
4800 dpi error
11-03-2023 04:15 PM
Hi taylanguney,
5. Click OK.
01-11-2024 12:21 AM
you have to go to settings for ScanGear. in there is a checkbox that says something like allow for large scans. once that is checked, you can TYPE 4800 dpi. however, the limitation is 50000x50000 pixels or 4GB, whichever limit you hit first. so at 4800dpi, the max size i can scan is 6.7 inches x 9.2 inches. that file will be just under 4 GB as a JPEG. TIFF will be astronomically larger I assume. then in a photo program, you can stitch them together into a bigger image.
08-02-2024 08:50 PM
This is the key, and easy to miss! you have to manually type 4800 into the resolution selector.
my "standard" selectable list only goes up to 1200 with the "enable large image scans" option selected.
01-11-2024 12:26 AM
