07-05-2024 10:07 PM
I'm unable to activate IP streaming on my xf605 as the menu item is constantly greyed out, and set to disable. Is there a funtion that I am missing? I am able to get the camera to connect to the multicam app and browser remote, but can't activate the IP streaming function. I am on the latest 1.0.4.1 FW as well. Any help would be appreciated to get this activated!
07-06-2024 12:18 AM
figured out it is actually the encoding format. I was set to MP4(hevc) and this would disable ip streaming. Changing to xf-avc allowed activation of ip streaming again. Maybe it's because the xf605 can't do hevc srt, it only does h264
07-05-2024 10:33 PM
Take dual slot or whatever function uses the b slot to record off.
The processor to stream utilizes the resources that record to b slot so you cant have all three happening.
Slot A Record
Stream or B Slot
07-06-2024 12:18 AM
07-06-2024 12:43 AM
Was just going to post this for you both. I don't have an XF605, so had to do a bit of research. My R5 C doesn't stream SRT
Supported streaming modes:
IP streaming cannot be used in the following cases:
- When using a recording mode other than [Normal Recording].
- When [2nd Card Rec Functions] is set to an option other than [Off]. (*credit Briankirwan)
- When using the web camera function (A 117)
Thanks both. This will be helpful for others.
