Worth the upgrade from XA50 to XF400?
Sumpurna
I currently own a XA50 and am looking to for an upgrade. Would XF400 be a good one, although it was released a few years prior to the XA50? Also, a Wikipedia article stated that the XF400 was similar to a GX10 just with the top handle.  Is that the only difference between the two models (XF400 and GX10)?
Mentioned Wikipedia article: https://en.wikipedia.org/wiki/List_of_Canon_camcorders
It appears you'd need to step up to either the XF605 or XF705 camcorders in order to get 4K 60.
Or, start looking into Canon's Cinema line; though that will be at an even higher cost than the two above cams, especially after factoring in lenses.
Ricky
3 REPLIES 3
To answer your question, basically yes.  These are comparable models functionally and spec wise.  You cannot get 4k 60 at a $2,000.00 price point currently.  Since the XF400 is discontinued you might be buying old stock or need to source used.  This might be a good reason to consider a newer model.
Which would be a newer model with 4k 60fps capabilities?
Ricky
Holiday
