Vixia hf r400
timmib
My wife has an hf r400.  I would like to get the clip off the camcorder and onto my computer (win xp sp3).  I thought to use the wifi cability but I use mac address filter and do not know where to find the mac address of the camcorder.  Then I thought to read the sd card directly; windows doesn't recognize it.  So before I start playing with software ....  Where do I find the mac address of the r400?  and  What is the format of the sd card?
TIA
Kim
Tim
Hello Timmib,
When connecting the VIXIA HF R400 to a computer via an access point, the MAC address can be viewed after the connection has been established.  In most cases, its a matter of pressing the WPS button on your router and then touch the camcorders screen.  This is the easiest method to use if you are on a WPS network.
The format employed for the media cards is exFAT.
2 REPLIES 2
Tim
Hello Timmib,
Greetings Tim,
Thanks for your answer!!
Be well,
Kim
