Vixia HF R70 Not Connecting to Computer
aduea
My new R70 camcorder won't connect with my computer. When I plug in the USB cord, it appears to run but then stops. I don't get any error message.
I've tried:
- Using a different USB port
- Turning off camera, unplugging USB cable and starting over
- Restarting computer then plugging in camcorder's USB cable
- Uninstalling its USB controller and re-install, but can't find any controller that looks like it would be for the R70 USB
The movie format is set up as AVCHD. I'm using WIndows 7. Please assist!
3 ACCEPTED SOLUTIONS
Do you have it in playback mode instead of a shooting mode?  If not, try it and let me know if it doesn't work.
Look on page 64 of the manual for the proper setting for playback.
That was the problem - don't know how I missed it. Thanks so much for your help!
9 REPLIES 9
VideoGeek
Mentor
Have you tried using the Transfer Utility LE software?
Yes, I've installed Transfer software and when I click "Import Video", an error message says that the camcorder is not connected to the computer.  Man Frustrated
What mode is the camcorder in when you connect it to the computer?
Movie format is AVCHD; shooting mode is Auto. Is that what you're asking, or should I look for another setting?
Glad I could help and glad that you are able to get the computer to see the camcorder.
Richard
Hi Aduea,
Thanks for posting.
When connecting your camcorder to your computer, please ensure that you power your camcorder, using the Compact Power Adapter, included with your camcorder.
When connecting your camcorder, if your computer is a desktop model, please ensure that its plugged directly to the back of your computer (Not a USB hub.). If your computer's a laptop, please ensure that it's powered with A.C. power.
With your camcorder powered by the Compact Power Adapter and connected to your computer via USB, power the camcorder on, then switch it to the Playback mode, using the Playback button (right next to the [On/ Off] button.
When you switch your camcorder to the playback mode;
  1. Does your computer respond (i.e. with windows, beeps, etc)?
  2. What do you see on your camcorder's display?
