Sigma DC lens on EOS C70
Ajjos
Will a Sigma DC lens work on the C70 with a ef-rf adapter? If so which adapter do you recommend?
rs-eos
First, the Sigma lens in question would need to have an EF mount.  Though do note that you'll most likely run into compatibility issues using a third-party lens via an adapter on Canon equipment.
If you don't already own this lens, strongly recommend you rent it to see if things will work out with your C70.
Ricky
2 REPLIES 2
rs-eos
Ricky
Thank you. Yes, I already own it, I’ll try it when we rent the C70 thanks.
