04-11-2025 03:34 AM
Is anyone aware if there are "internal" CFE card readers available to fit into desktop PCs (i.e. on a 3.5 or 5.25in panel); preferably with a SATA connection?
There is only one internal reader (Startech) that even has SC UHS-ii, & that uses a USB3.1 internal connector, & is not as fast (<200MBps) as the internal bus integrated reader on my Dell XPS (~250MBps).
Otherwise what external CFE readers have been found to work well?
Thanks!
04-11-2025 07:38 AM - edited 04-11-2025 07:40 AM
Some of us use the ProGrade dual slot card reader. PG5.05. It offers CFE type B and UHS-II support, and is backwards compatible. Angelbird makes a nice model too. They are about $80 bucks but you can sometimes find them on sale.
04-11-2025 07:40 AM - edited 04-11-2025 07:41 AM
I use the ProGrade reader that Rick mentioned. It can magnetically attach to the side of the computer housing.
04-11-2025 09:54 AM
I think you are about 10 years too late to look for a bay-fitting reader.
04-11-2025 02:49 PM
Hopefully not, internal bus connections are still much faster than USB.
