10-17-2016 06:48 PM
Hello,
I am having issues with green screen video. I am using an HF R300. I have lighting. After I use the default chroma key with Pinnacle Studio 17 on a clip I shot, residual black "noise" is present. Here is an example where I removed the green background and replaced it with an orange jpeg.
Here is when I used a sample clip from the internet. following the same procedure with the Studio 17 software. as you can see there is no "black noise".
I have tried many lighting changes. Nothing helps.
Is it the settings on the camcorder that need to be adjusted?
Thanks for all your help.
Rande
