08-02-2023 10:27 AM
I've had my R5C for less than 4 months and my micro HDMI port is no longer sending signal to my monitor/s. There are zero signs of damage to the connector. I even looked at it under a loupe. No bent pins or anything. USB-C above it works fine but the whole connector assembly appears to have movement in it, so it's possible the internal cabling/connectors could be severed. I've been using a protector cage since day one. It does get unplugged and plugged back in constantly as I go between Cinema and stills. (It's my only camera other than an RP)
Have tried multiple cables, and other monitors. Zero signal. I take my monitor and connect it to the RP and it works fine so it's definitely the connector. Am I stuck paying a huge repair cost or could it still be under warranty? Camera was purchased new in April. Any recommendations? I don't want to be months without a camera.
08-02-2023 10:44 AM
Give support a call first - just to make sure it's not something silly. They're at 800-OK-CANON. (800-652-2666).
08-02-2023 10:36 AM
I would send it to Canon for evaluation. I would assume it would be covered, as long as there are no signs of abuse.
08-02-2023 10:38 AM
Thanks I suppose I'll open a case with Canon then.
08-02-2023 10:44 AM
08-04-2023 04:43 PM
Try to factory reset the camera first. It's most likely the connection but couldn't hurt trying before sending off for repair.
08-04-2023 10:45 PM
@Chris,
Camera has a 1yr warranty from Canon. Perform the reset as suggested. Get a case opened. Contact support and work with them. Although this is the busiest time of the year year, I'll bet you have your camera back in under 2 weeks. Turn around is usually within 5-6 days. Bummer it happened.
08-10-2023 08:03 AM
I called and opened a case. The tech and I ran through some scenarios and tried everything. HDMI is dead. They suggested I send it in so will do so in the next few days.
08-10-2023 09:34 AM
I have posted it before but:
https://www.lensrentals.com/blog/2019/08/why-side-mount-buttons-and-ports-break-on-cameras/
