EOS C80 - Audio Rec Level not available with monaural mics
dru_nasty
Canon C80 - I have no problem when i'm running two mini xlr inputs into channel 1 and 2. But, when I run just the line in with a DJI wireless for ch 1 & 2 then use monaural for 3 & 4 i don't have the option to set the levels for the monaural. That options is grayed out on the menu.
Not sure what your question is, but this is as per the manual.  The mono mic is just for scratch audio, and has auto level control.
2 REPLIES 2
dru_nasty
I was not aware that it is only automatic level control. Thank you for clarifying.
