EOS C200 Internal ND filters stopped working
vikhral10
Hi, I recently bought a c200 and had the ND filters working and then they stopped working. The ND filters actually move when I turn the cameras on but fail to move when I press ND +/-. Does this need to be repaired and how much do you think it would be. The camera function well other than that.
1 REPLY 1
John_Q
Hello vikhral10,
Let's try resetting the camera to default settings to see if that helps. You can find that setting in the [System Setup] (wrench) menu. I would suggest doing [All settings]. If you would like to save the settings on the camera to an SD card prior to the reset, you can do so. This is also found in the [System Setup] menu listed as [Transfer Menu/CP]. You would need to use SD card slot B. If this does not resolve the issue, then the camera may need to be serviced.
The factory service centers use a tiered pricing structure for repairs/service based on the type of service that is needed on the equipment. The tiers for that camera are as follows:
Minor = $269
Standard = $359
Major = $499
Unfortunately, I do not know what tier this particular issue would fall under. The FSC would provide that estimate to you once they have had a chance to look over the camera, and you have provided them with the problem description.
