10-03-2022
05:21 AM
08:04 AM
I am using a Canon XA11 camcorder with the Canon 250D and panasonic Ag-ux90 4k. Setting up the cameras and seeing on computer screen the Canon xa11 is not compatible with the other cameras. Please help me on this because i was thinking of selling it and get another DSLR camera. Thanks
10-03-2022 08:39 AM
What do you mean by "not compatible"?
10-03-2022 11:09 AM
The video quality on this to do with brightness, contrast and saturation
10-03-2022 02:02 PM
This is a pretty common problem usually solved in post, though I can certainly understand wanting to minimize that hassle.
10-03-2022 06:54 PM
Trying to match video cameras (e.g. A, B, C cams) can be tricky. Especially across brands. But even within the same brand if using different devices (in your case a cam vs. DSLR). I don't think an Log options exist on the 250D, so you'd probably be stuck with Rec.709 there. Though maybe it has a WideDR option?
Ideally, you'd want to use the same brand and I'd recommend all capturing either CLog2 or CLog3 (or whatever equivalent a particular brand uses).
You'll prob need to experiment. And there may be other videographers that have available LUTs to apply in post to try to get the footage more equalized.
10-04-2022 01:27 AM
I have tried even using an external ND filter to the Canon xa11 but still the video quality for it has much white light
