Canon VIXIA HF G30 Zoom toggle switch problems
vid12
Hello group
I have a Canon VIXIA HF G30 that I purchased in February 2015.  It just recently developed a zoom toggle switch problem .  Occasionally I'll zoom in or out on a target and release the toggle switch and the camera will continue to zoom in or out a little bit.  Has anyone heard or familiar with this problem and if so is there anything I can do on my own?
Furthermore I got an estimate from Canon today and they want $425 for a new toggle switch.
Thank you
Don't get the toggle switch on your camera fixed.  I went to Canon technical repair in New Jersey and spoke to them personally.  They told me that the cameras toggle switch can be bypassed by using a external zoom.  This is what I purchased. Manfrotto MVR901ECPL.  This exterior toggle switch works absolutely perfect.  Do yourself a favor and follow my good advice purchase it.
8 REPLIES 8
Waddizzle
This question might be best posted in the camcorder forum.
It sounds like you have a dirty, or sticky, switch.  It either needs cleaning, which may be near impossible depending upon on how the switch is made, or a complete replacement.
How do you store the camera?  Has it been exposed to dirt, humidity, dust, or some other airborne contaminent?  Dirty fingers?
You hit the nail right on the head.  I video horse shows and as you can imagine there is a lot of dust in the air.  That's why I'm just using an $1100 camera opposed to $5000 camera.
It just strikes me funny that the switch would go so soon.
Not sure how I get to the camcorder section, could you please tell me?
Thank you for your reply!!
Forget it now I see camcorders at the top of the screen.  Stupid me how did I not see that before.
Yeah, but, the $5000 camera is likely to have a body sealed against dust and humidity.  Likewise, for lenses it could use.
yyazz
I don't visit horse shows but have the same problem and after 3 year for the second time !!! Bad Switch or even bad camera. First time warrenty second time I am very angry because i have to pay of throw it away .... after 3 years !!! Once again Bad service and bad camera.
JtTheWoodworker
Bought my G40 a couple years ago. Been suffering with random zooms ever since. Purchased an external LANC control for zoom. Problem still there. The camera zooms out when it wants to. No stopping it. Pitiful when videoing important events.
Stay away from Canon video cameras I guess.
Very disappointed.
Will try the air/cleaner trick, but this shouldn't happen with a $1200 camera so soon.
All videoing indoors. Camera kept in dust-free case when not in use. Use about 5 times / year. So within about 10 uses, problem shows up. Arg...
Actually, this series of cameras is notorious for the camera rocker switch, regardless of if you shot in a clean room with hard drives or a rodeo.  its the only thing i hate about Canon!
Hi Andrew. With my G40, I can cause the problem by just rubbing the case next to the switch. Almost like its a grounding issue. Have thought maybe using the switch manually causes me to kind-of hang my arm weight on that switch. I bought a new one, but haven't installed. Still zooms once in a while. Before any shoot, I pull up on the switch. Seems to help. Still using external zoom control.
