03-19-2025 10:05 PM
Hi there,
I just bought a used C300 Mark III (EF Mount) - and it's basically mint with this one major exception. Autofocus won't work, Image Stabilization won't work, Servo won't work, nor iris. Strangely, I can adjust the iris using the menu, but it doesn't have any visual effect on the image.
Lens data is transmitted to the camera. I can see an iris value, focus guide, and focal length.
I've tried the CN-E 18-80mm T4.4, 70-200mm F2.8 L II, 24-105mm F4 L, 50mm F1.4, 35mm F1.4 L (all native Canon EF glass)
The above all work on both of my Canon R5's with the Canon RF-EF Adapter.
I've also tried delicately cleaning the lens contacts, resetting the original settings, and updating to the most recent firmware. I've also made sure all AF switches are thoroughly switched to AF and that settings in camera are set properly.
Any thoughts? Thanks in advance!
03-19-2025 10:31 PM
Where did you purchase this camera? Do you have the right to return?
I'm not trying to nix your purchase but those are some huge hurdles to overcome. Me personally, I think I'd return it and continue shopping.
The only other option I see is Canon support for inspection and repair. If the behavior continues after a factory reset, and with multiple lenses, I suspect something is very wrong.
03-20-2025 08:52 AM
Hey there Rick,
I purchased from a seller on eBay - I know, not the most confident of purchases, but the seller seems like he wants to do what's right. I figured I'd troubleshoot for a little bit and if I couldn't find a solution, he'll accept a return.
I was just hoping there were 1 or 2 more things I could try before throwing in the towel.
Thanks,
Brian
03-20-2025 11:05 AM
Hi Brian,
By testing with multiple lenses and performing the main settings reset, you've done everything that could be expected😄.
I suggest walking away. There will be other deals.
