C200 footage playback extremely choppy
haymanstudio
Hello!
I'm relatively new to using the C200, and have noticed the 4K footage plays back very stuttery, jumpy, etc, in the codecs offered in-camera. I've used 4k ProRes in the past, out of BlackMagic cameras, and never had any issues playing back the footage, even from an external drive using all kinds of color grading effects.
Proxies may be a work-around, but is this just how the footage is without them? Is there a way to use the ProRes on the C200? What are my options here, as I'm leaning more towards selling the camera and just buying a BlackMagic camera again.
My PC specs:
GPU: Nvidia 1080 Ti
CPU: AMD Ryzen Threadripper 2970WX 24-Core
RAM: 32 gigs
Thank you!
-Alex.
Mark35mmF2
Hi there Alex,
Yes, generally with those specs it would probably be better to use a proxy file to get around this for the C200 clips. Those .MXF files can take a bit more processing power to playback than a more common format like ProRes. The camera does not shoot ProRes internally but recording to an external recorder or converting prior to beginning your edit would be a way to get those clips into your preferred ProRes format.
2 REPLIES 2
Mark35mmF2
Hi there Alex,
Thanks for the response! I appreciate it.
