05-27-2018 01:50 PM
Hey there,
Was recently shooting Canon Raw Light. Camera died whilst shooting, and the C200 did not combine the raw light data files for the actual video file. All I had on the memory card was a 1) .DAT fle and 2) a .DMV file.
Is there anyway possible to combine these or recover the video on them?? It seems like it should be a pretty simple fix/script to remedy.
06-11-2018 03:04 AM
I just had the same problem. Try puting the card back in the camera and watch media on the camera. It will come up with a question mark. When you try play the clip it should give you the option for recover the clip.
This worked for me! Good luck.
Alex.
06-11-2018 03:04 AM
Alex.
06-29-2018 03:32 AM
07-03-2019 08:57 PM - edited 07-03-2019 08:58 PM
@Alex - you ABSOLUTE LEGEND. Saved me. Thank you!!
08-01-2019 01:15 PM
Worked for me too! Thanks!
10-19-2021 02:48 PM
Is there an option to recover the .CRM film file without in camera recovery? The original SD card was formatted so I only have access to the .DAT & .DMV file on the computer. Any suggestions? Thanks!
12-11-2021 11:44 AM
Hi everyone,
Re-opening this thread, I have a few corrupted .CRM files that were shot on the C300 MK III. The original media card has been formatted so the in-camera repair solution isn’t an option. As Isabel, I’m looking for a software solution to fix these .CRM files. They won’t open in Premiere or the Canon RAW utility. Any information would be appreciated! Thank you!
Jae
12-13-2022 09:32 AM
Hello
Same problem, but the solution to put the card in the media session doesn't work for me...i recorded on the SD card on MP4 format/// so i can"t read the corrupted files on the media session, because the media session only read Raw files....any suggestion?
06-08-2026 01:04 AM
I managed to recover and fix a .crm canon raw light file, from a Canon C70, and recovered from an SD card, by using Claude to drive the mac terminal app to assess/fix the file.
- Recovered a .crm, as well as a .dat and .dmv file using Disk Drill.
- Crm file showed image preview, but didnt work in any video editor.
- Claude gave terminal commands to copy an image of the sd card
- then analysed the file in various ways via terminal
- analysed a 10 second clip, recorded in camera at the same settings as recovered clip, compared.
- adjusted clip internals to match
- bit of trial and error, but finally got a working file - audio and video work.
I've documented my Claude-driven process here - with Claude notes on things tried and scripts to use: https://gist.github.com/jeanpoole/54f1e923034cf973bd473bd846246e72
06-08-2026 01:05 AM
