04-07-2023
02:32 PM
02:46 PM
I have the ImagePrograf 300 printer. Unfortunately, I was in desperate need for Canon's luster paper, however, all our local camera stores either were out or don't carry the size I needed. The only paper that came close to what I needed was Promaster Pearl. When I went to their website for the ICC paper profile, they haven't updated their files to the current printers. There is a profile for the Pro 10, but not the Prograf 300. Would I be able to use this, or is there a vast difference? Thanks for any information!
04-10-2023 11:19 AM
https://ij.manual.canon/ij/webmanual/ProfessionalPrintLayout/M/1.3/EN/PPL/ppl-414.html
If the Canon profile isn’t too far off maybe you can fine tune settings.
04-10-2023 07:14 AM
If you feel the Promaster Pearl surface is close to Canon Luster did you try printing using the Canon profile?
04-10-2023 11:13 AM
It is. I did use it *Canon's Luster icc) as I was desperate. Since the Pro 300 replaced the Pixma Pro 10, I thought perhaps I could use this. I haven't as of yet (downloaded the icc Promaster Pearl), as I am now understanding from various sources, the colors on the Pro 300 are actually different from the Pro 10 because of the different algorithm. I have since ordered (and just received) Canon's Luster paper. I guess the only alternative to the Promaster, would be to have a custom profile done, but I don't want to spend the $ if I don't plan on using their paper in my normal printing.
04-10-2023 11:16 AM
Did the Canon profile not look good?
Depending on how “off” it is maybe you could use the Pattern Print feature in PP&L to fine tune the print settings.
04-10-2023 11:19 AM
04-10-2023 12:29 PM
Thank you so much! I am going to try this.
