04-22-2023
10:54 AM
01:46 PM
I've just replaced my Pixma Pro 100 with a Prograf 300. I have a small greetings card business and had custom size settings set on the pro100 but the 300 doesn't seem to have the option to create custom sizes. This is a real problem for me. Any suggestions?
04-22-2023 04:43 PM
Canon : imagePROGRAF Manuals : PRO-300 series : Setting Paper Dimensions (Custom Size)
04-23-2023 04:22 AM
Hi John,
Many thanks for your reply. I use a program called Serif CraftArtist for my greetings cards. When I had my pro 100 there was a Custom size facility in print dialogue window, however, since getting the prograf 300, the Custom size option is just not appearing in the dialogue window.
Dawn
04-23-2023 06:30 AM
Hi Dawn. So you mean the custom size window you used was in the Serif software? Do they have a help line?
04-24-2023 09:27 AM
Hi John,
Unfortunately the Serif programme I use is now obsolete and so there is no customer service contact. When using the programme with my Pro 100 I simply clicked on 'print' and a very long and comprehensive list of print sizes appeared. At the bottom of that list was 'custom'. I had already created my custom print settings for my cardstock and had it saved. Now though, when I go to 'print', a very small list of available sizes is displayed and no option whatsoever for 'custom'.
Dawn
05-02-2023 12:34 PM
Hi DC6523,
Are you using Windows? If so, what version?
If you are using a Mac, what version of OSX is installed?
Are you using your imagePROGRAF PRO-300 wirelessly?
or with a USB cable?
05-03-2023 04:18 AM
Hi Patrick,
Thanks for replying.I'm using it wirelessly and on Windows. I finally got a tech professional in to look at things. Turns out the install instructions in the manual weren't clear or comprehensive enough (for a non tekky!). It's all sorted now.
