02-08-2025 02:39 PM
Hello Team,
I have brand new pro-1100, I started the installation, plug the ink, put ON followed the instructions.
next step to add the printer head into printer but the the printer head did not move to the maintenance position,
printer head stays at the parking position, have never moved to the maintenance position, I turned OFF and tried again, now display "Support Code 1881" which means that the head is not installed properly. This message should not even appear, because the setup was not started, and obviously the head is not installed. When I raise the top cover, as advice by the message, nothing happens, the head compartment is still collected, not allowing to do anything. There is no button to delete this message and continue the normal setup.
Any idea?
02-10-2025
01:56 PM
03:11 PM
Hi home306,
Please contact one of Canon's Technical Support Representatives via phone or chat. To contact a Technical Support Representative, please use the link below to log into your My Canon account:
https://mycanon.usa.canon.com
Once logged in, click on your imagePROGRAF PRO-1100 and then click on the Product Support button. When that page loads, click on either the Phone Support button or the Chat Support button to access support. A Technical Support Representative can determine the cause of the issue and resolve it or provide you with your available service options.
02-10-2025 02:23 PM
Thanks Patrick, still waiting the response from the technical support since Friday.
Unfortunately my imagePROGRAF PRO-1100 is not registered because of that I get no support for a brand new printer. Canon process works very slowly 😫
02-13-2025
02:33 PM
03:11 PM
Hi home306,
I do not understand what you are referring to.
Why are you unable to register your PRO-1100?
Do you get an error when you attempt to register it when logged into your My Canon Account?
Also, how did you contact technical support if you did not register your PRO-1100? Who are you waiting a response from? I do not see an instance of when you would have contacted support.
02-16-2025 04:05 AM
I contact over 1 week Canon techn. support with no response via e-mail or telephone.
my printer with my serial no. is not registered therefore I don't receive any technical support.
I registered over one week my printer, sent a copy of invoice, picture from the serial no.
The back office is not able to do this my device in their systems
I call the hotline daily and if I gave me serial no... answer: is not in our system currently
To be honest, I didn't expect that from Canon Support at all
I have several Cameras and Lenses ...I have never seen anything like it of very bad support
02-16-2025 09:14 AM
Welcome to the Canon Community!
The Community isn't intended for immediate assistance. If your question is urgent, please call technical support directly at 1-800-OK-CANON (800-652-2666). They're available Monday through Friday from 9am to 6pm (ET).
If you're outside the USA, please click HERE for support options.
