Recognizing Pro 100 printer
Iguana
Hi folks, This is a bit weird. I print from Lightroom and have two printers set up but going to the same Pro 100 printer.
They are called : Canon Pro 100 series   and Canon Pro 100 "series 2"
I can print fine from the series 2 profile but not from the Canon Pro 100 series.
I want to do a deep clean as I am getting some weird stuff happening but can't do it from the Canon Pro 100 series 2 profile as the Canon IJ Printer Utility doesn't recognize the "Series 2"  - only the Canon Pro 100 series which then says the printer is off line.
How do I make the Canon IJ Printer Utility recognize the "Series 2 " profile or why can't I just print off the Canon Pro 100 series  profile.
I think I am going mad - madder ?
Any suggestions ?
5 REPLIES 5
jrhoffman75
Try deleting the "series 2" printer in Printers & Scanners using the "-" button. When that's done right-click on the Pro-100 and reset printing system.
That's how I corrected a situation where I inadvertenly got two versions of my printer.
Hi John,
Many thanks for your advice. It did the trick and took about 2 minutes as opposed to the several hours I spent yesterday fiddling around. Onwards and upwards. Cheers from New Zealand. Paul
ebiggs1
" I print from Lightroom and have two printers set up but going to the same Pro 100 printer."
Do you mean you have two physical printers? Or, did you just install one printer two times?  I have use four printers at one time and didn't have any issues.  I use LR and PS exclusively to print.
I am on Windoze not a Mac so if you have a Mac I am of no help.  But I suspect a complete uninstall and reinstall is on order.  Don't leave any drivers or files behind.  Get rid of every one before you reinstall.
Got sorted thanks and yes , basically did a complete uninstall and reinstall which got rid of the duplicate drivers which was the problem.
jrhoffman75
Glad I could help.
Enter for a chance to win!
April 20th-28th
