08-12-2023 03:50 PM
I am using a Pro 300 printer. I have downloaded the ICC profiles for Canson Infinity papers (Platine and Baryta). The ICC profiles are visible in Lightroom Classic. What settings should I use on the actual printer menu when registering these papers as they are not shown on the menu?
Any help is appreciated.
08-12-2023 08:06 PM - edited 08-12-2023 08:14 PM
Canson should have that information on the website where you downloaded the profile or in a pdf they included with the download. My “guess” would be the plus semi-gloss media type.
I just looked, Canson actually provides the AM1X media files. You will need to use the media configuration tool (MCT) to install them. If you did that already you can look in the MCT to see where it put them, probably in Custom.
08-14-2023 11:57 AM
Thanks! Will try.
