12-24-2020 05:21 PM
I'm geting a bit of black ink on the leading edge of my prints out of my pro-1000. I ran a cleaning cycle, but that didn't resolve the issue. Anyone know what might be causing this and how to fix it?
12-25-2020 05:56 AM - edited 12-25-2020 05:57 AM
Canon : imagePROGRAF Manuals : PRO-1000 series : Cleaning the Paper Feed Roller
12-24-2020 07:40 PM
Does your printer have a roller cleaning or bottom plate cleaning option in the driver?
Typically, when folks say they ran a cleaning cycle they are talking about running a prin head cleaning for plugged nozzle correction.
12-24-2020 09:15 PM
If it does, I didn't see it in my utilities..
12-25-2020 11:50 AM
Thanks John...!
02-04-2021 04:35 PM
I have the same problem especially on the leading edge. It seems to have more to do with the paper thickness as it makes a racket as the leading edge begins to print. I've set the printer properties to FineArt Heavy Weight paper and I'm using the manual feed as is required but it doesn't seem to make a difference. I ran the roller clean but that had no effect. Any other suggestions for printing heavy weight papers?
I'm using Lightroom and ICC profiles specific to paper and printer.
02-04-2021 05:37 PM
