11-07-2013 05:44 PM
I replaced a HP Photosmart B8550 with a Pro-100 recently. In printing images both that I printed previously on the HP and some I have only printed on the Canon Pro-100 I am having frustrating results. I am getting darker prints and less intensity of color from the Canon. My paper is Canon Paper Plus Semi-Gloss. I end up having to adjust the brightness and saturation using Photoshop Elements 10. Otherwise this is an excellent printer
11-16-2013 08:56 AM
Hello Stuart.
Additional troubleshooting will have to be done to narrow down the cause of the issue that you described. Please contact our support group using the link below for additional assistance.
http://www.usa.canon.com/cusa/consumer/standard_display/contact_us_consumer
11-16-2013 12:17 PM
I am very confident in saying your Canon Pixma Pro-100 will never print the same as your HP did.
There are just two different design philosophies between the two companies involved here. I use both HP's a Canon printers.
I prefer the Canon's over HP's (right now!)
First and foremost your monitor must show you what you are printing. If it doesn't than you may as well take up fishing instead.
Confirm this before we go any farther. If you set your gamma and grayscale correctly that may be all you need do.
Windows has a built in calibration feature and you can make use of it. I don't know if MAC OS has that but in either case it must be done.
