05-19-2022 10:21 PM
We have Pro-10 and it started printing much lighter all of the sudden. We did just change the PM cartridge. But a printer nozzle check looks fine and we even changed the PM cartridge again just to be sure. We sell prints, so unfortunately we are dead in the water at the moment. I'm not sure what else to look at. We usually print from Adobe Reader because we save our finals as pdfs. But the issue also occurs in Photoshop. They look exactly the same in either program.
Any ideas?
05-20-2022 08:16 AM - edited 05-20-2022 08:16 AM
Welcome.
If the nozzle check looks good then the question would be have there been any changes to the computer such as an operating system update.
Also, sometimes reinstalling the printer driver can be helpful.
If it was my machine I would also run a head cleaning cycle just to be sure.
Download and print this test image using Photoshop to see how it prints.
https://1drv.ms/u/s!ApNpngg2Z6dbhIYEVaNQBuYp2nUaWg?e=fYYhGf
05-20-2022 02:25 PM
Thank you John. I will try the image tonight. My thought was about computer changes as well, but we print across two computers and they both present the problem. It does seem like it would be software if the nozzle check looked good. I did run multiple cleanings and even a deep clean.
05-20-2022 02:36 PM
I'm confused how two different software products on two different computers could both act up like that, unless its a problem related to how the PDF is created. Then both software on both computers would be correctly printing a file with a problem.
Do you have files created before the problem started?
Do you have photo software other than Ps that you could use to print the test image in addition to using Ps? Since I know that the file is good that would reveal a potential software issue, and if both images print the same but not correct then it would indicate a printer problem.
05-20-2022 03:10 PM
All of the files were created before the problem started. And all of our prints suffer from the same problem. I have PS on one computer and Adobe Reader on the both and I get the same thing across other. I don't have another pro editing software. The prints do not look horrible. You might even think that's what the print should look like in some cases. But we have prints in stock from before the issue started and there is a stark difference. The primary PDF that we have been dealing with has not been edited since last October and the problem started Tuesday, but again, all of our prints are off. Thanks again.
05-20-2022 03:43 PM
OK. Just print the test image from Ps then.
05-20-2022 08:16 PM
Hi John. I printed that image and it looks OK to me. I don't have a "before" option, but it looks like I would expect it. Again, even the "bad" one wouldn't seem that off if you didn't have the "before" option to compare it against. I'm confident I can get things back to "good" again. But I'd be recalibrating a ton of images if I need to do that. I'm not sure what the next step would be. I appreciate your input so far an welcome any further thoughts you might have.
05-20-2022 10:26 PM - edited 05-21-2022 08:28 AM
If you are using Windows computers you can go into the printer driver and adjust the printer output.
After you create the Pattern Print you select the image that looks best to you and then adjust the sliders to those settings.
You can then save it as a preset (maybe call it Adobe) and select that preset when you are printing the PDFs.
05-21-2022 09:49 AM
Thanks, John. I'll try this. As you can see below, the images aren't really bad, just really different. Thanks again and I will try your suggestion.
05-21-2022 10:03 AM
This is on the same paper? Are you using Canon OEM inks?
