06-05-2020 04:02 PM
I've asked this question previously and decided to ask again in a different way to see if someone can help me. Can you tell me whether you can remove the cartridges and printhead from a Pro 10 and then reinstall a day or two later? I understand it will probably initiate a cleaning cycle and waste some ink. My objective is to put the head and carts in a different Pro 10 and continue to use. Thanks for any thoughts or suggestions you have!
Regards,
Bill
06-06-2020 07:09 PM
Hi Rick,
Ebiggs1's Answer was fine. I just hadn't received it by the time I wrote the above recast of the original question!
I spoke with a Canon a couple months ago and he said all I would have to do would be to leave the idle printer on and the printer would take care of itself. I guess that's going to be my approach even though it will also waste some degree of ink.
Thanks for the your help.
Regards,
Bill
06-06-2020 06:40 PM - edited 06-06-2020 06:44 PM
Hi Bill,
The answer is the same .... you want to move the printhead and inks between 2 Pro-10's at different times of the year.
What was wrong with Ebiggs1's answer?
https://community.usa.canon.com/t5/Professional-Photo-Printers/2-Canon-Pixma-Pro-10s/m-p/308740
While I think it it could work, you will lose ink every time the head (carrier) and inks are moved. For optimal results, you'll probably have to perform maintenance, including a nozzle check and alignment after each move. Not sure its worth the expense as previously pointed out.
06-06-2020 07:09 PM
Hi Rick,
Regards,
Bill
