Printer prints black ink spots and lines on the backside of cardstock paper
Sugaree
I have tried cleaning via the utility for bottom plate many times but whenever I use 110lb cardstock these black dots and lines, mostly on the edge of the left side of the paper, are on the back. I am at a loss as to what to do. I did every cleaning option, please advise as to how I can manually try to clean this.
thanks
9 REPLIES 9
jrhoffman75
what size cardstock are you using?
110 card stock..neenah
Is it a standard printer paper size, like 8x10, etc.?
It is 8.5 x 11
jrhoffman75
If you open the cover where the ink is you can carefully wipe the metal strip that is there to see if there is any ink on it.
I don’t have experience printing on cardstock. If it is thicker than printer paper maybe setting the reduce paper abrasion setting in the printer driver would help. Just a guess.
thanks...i did try that as well..Nothing has helped but I appreciate your help!!
jrhoffman75
Give Canon a call at 1-800-OK-CANON
Yes going to have to call canon if no one here can help.
thanks!
Avatar
