02-22-2015 07:29 PM
02-22-2015 07:30 PM
02-23-2015 06:05 AM
Did you try to turn the printer off, unpluged form the power for a 1/2 hour or two? Can you print at all, anything. If you can, it is probably a problem with your OS or software.
03-14-2015 10:30 AM
Did you select manual feed tray as the paper source? If not I think it assumes you are using the rear tray feed.
