12-13-2021 01:36 PM - edited 12-13-2021 04:18 PM
I need a contact that can verify if a sheep hair Hake Brush will be safe to use to sweep small particles off of the glass surface, especially the edges. Specs here: https://www.gaylord.com/Preservation/Book-%26-Pamphlet-Preservation/Repair-Tools-%26-Supplies/Brushe...
Co-worker is refusing to use because the manual says soft cloth, believe this brush is as soft or softer than a cloth.
12-13-2021 04:13 PM - edited 12-13-2021 04:15 PM
Use canned air and keep the scanner covered when not in use. It doesn't matter how clean you are, all houses are dusty. If you have pets, hairy too. A soft bristle brush, clean soft cloth and canned all works great.
12-13-2021 04:20 PM - edited 12-13-2021 06:09 PM
I agree with you about the canned air. I work in an Archives and as I posted above, she refuses to use ANYTHING other than a soft cloth as written in the manual. I would like a contact for someone at Canon that can confirm that a Hake Brush, canned air, and the like can be used on the glass.
12-13-2021 04:35 PM
Hi there!
The Canon Community Forums aren't intended for immediate, urgent assistance from Canon Technical Support.
If you've registered your scanner, as we suggested on Twitter, you'll see options to contact support within your My Canon Account. Email support may not be available for your product. You will see all of your support options at canon.us/account
12-13-2021 06:05 PM
Believe me, I tried that first. This is not an urgent need, just a frustrating one.
12-13-2021 05:06 PM - edited 12-13-2021 05:07 PM
Its glass. Nothing natual or synthetic will hurt it. Its not like you are proposing using a wire brush on it. Canon will not tell you to use a brush... they recommend cloth. I use air. T- shirts work great too. Your work colleague sounds like a nightmare. Good luck.
12-13-2021 06:07 PM
She is. Thank you for acknowledging that I am not a scanner destroying maniac that wants to used an Archival tool...in an Archives.
