09-02-2015 08:55 AM
Hi!
Brand new to digital printing, after many years in the darkroom.
I made some test prints with my new pixma pro 100 and it's printing very cool (blue) on black and white prints. I understand that I need to calibrate the printer - and I see that a calibrator is VERY expensive, but there is an option to send off test prints to someone else and they will send me calibration info. Is that the best way to get things up and running?
Some info: Using os-x yosemite 10.10.5. Think I'm am going to order Ilford Gold Fiber Silk paper.
Any info would be very helpful!!
Thanks!
09-03-2015 07:23 AM
Are you printing a color image and allowing printer to print grayscale, or are you printing a B&W image?
If you are printing a B&W image be sure to turn OFF grayscale printing option.
09-05-2015 03:58 PM - edited 09-05-2015 04:01 PM
You are the first person I have run into that said the Pro 100 printed cool. All I have seen have been warm biased. But ........
First, you must not let the printer set anything. Turn off every bit off control it has. You can do this with the Canon My Printer under the Printer Settings tab. Do you know how? I will guess, yes, for now but if you don't get back to me.
Second, you need to have your photo editor (like Photoshop) handle all the settings and color matching. You know how to do this? I prefer Photoshop and I use AdobeRGB color space.
And lastly, it is essential you get some settings on your monitor that somewhat matches what the printer is printing. Your printer may be doing exactly what you are telling it to do and you have no idea it is, because your monitor is so far off. If you don't do this step, you can forget the other steps. However, there are only a few things that you need to be concerned with. You don't need any fancy, expensive extra add-ins to do this. No additional software or gadgets, etc. Widows, I assume Mac, has these adjustment features built in for free.
Most people set their monitors too bright.
You must get the gray-scale very close. You need to get the brightness very close and you need the contrast very close.
After you do these things you can make adjustments to your prints by just looking at your screen. Because you know the monitor and printer are on the same level. One more point, you can NOT get a printer to print every color exactly the way you saw it. It isn't possible as all colors and adjustments effect all others. My goal is to get the skin tones right. That is what people notice most. Remember you are dealing with two different disciplines here. One is colored light and the other is colored dyes. They are not the same thing.
For instance, I know my Pro-100 tends to print darker than what I see on the monitor (typical). So, I automatically know to set it's prints 1/2 to one stop brighter in Photoshop, in my case. It also prints with a slightly warn tone. Most of the time, with portraits especially, this if OK but sometimes it is not. In that case I adjust the "temperature" setting slightly cooler in PS.
All the Canon photo printers I have ever seen have this warm/magenta cast. Canon engineers must prefer this look. It can not be changed. You need to "fix" it in post.
Make sure you have the correct ICC profiles and you are using Canon brand ink and paper until you get good with the printer. Very, very important, otherwise you don't know if the printer is doing exactly what you are telling it to or not.
Important, use the USB connection until everything is right. You are just adding another issue when you try to set up the printing and the wireless all at the same time. Just like using Canon branded products until it is a go. Use a real printer USB cable, too. Not just any old USB cable. Get everything right before you explore.
I just, well last year closed my darkroom down. It is a storage room now!
