06-21-2025 04:49 PM
Hello!
I recently purchased a new Canon Pixma Pro 200s. I purchased it because my Pro200 started printing photos like this. I had tried everything on the 200 and couldn't get them to print correctly again. So, I purchased a new one and it is doing the same thing. I'm running a Mac Mini and have the latest software installed. I downloaded the IJ driver and it's not fixing it. I'm also using Canon original ink, Canon photo paper, and, I am printing on the glossy side. I've attached a picture to show what's happening. They kind of look like paintings:
06-22-2025 12:51 PM
Hello. This looks like you may have printed the wrong side of the paper. Can you easily touch wet ink with your finger? I have done this myself, selected the wrong side of the photo paper.
06-22-2025 12:51 PM
06-22-2025 01:48 PM
It is the glossy side of the paper. I flipped the paper over and it did the same thing
06-22-2025 02:33 PM
You were right! I kept messing with it and finally,🙄 I got the right side of the paper.
06-22-2025 07:19 PM
If there is no marking on the backside then use this technique.
Wet a finger tip and touch a corner of the paper. The print side will be tacky because it is the side that absorbs the ink.
