02-06-2020 12:11 AM - edited 02-06-2020 12:26 AM
I have some issues with my Pixma Pro-100: when I try to print a picture on 5x7 paper (borderless), on macOS (10.14.6), the preview is OK but the print doesn't fill the paper and cover only a quarter of the size of the surface (the result is a tiny picture printed on the upper-right of the paper).
I tried many things (and waste ink and paper!!!): reinstalling drivers (I'm using the Canon IJ Network one, NOT the Bonjour one), reset printing system (in the macOS Preferences), print with different software (ex. : Apple Photos and Apple Preview), restart the computer, select again the paper size (in Paper Handling section of the print dialog box), I tried the USB driver, etc.
I try to find some help in the manual but it is completely outdated (because many changes were introduced in the last versions of macOS)!
What can I do, because for now I cannot print and I'm tired of wasting ink and paper. 😞
Thanks!
02-06-2020 10:23 PM
After wasting many liters of ink and a pack of paper, I think I found a solution, but I'm not sure to fully understand it!
In Printer Feature if you select Quality: Super Fine, you need to select Output Resolution: 1200 dpi! It seems to be bad programming from Canon!!! How I'm suposed to know I need to change the Output Resolution if I change the DPI?!?
Is there some updated instructions about the configuration of the printer driver on macOS? Because the Pro-100 manual show only the old printer driver and its completely outdated!
Thanks!
02-07-2020 02:47 PM
Just curious what software you are using that gives you those quality choices. I never see them in Lightroom.
02-07-2020 06:48 PM
