12-02-2015 05:58 PM
I have a PIXMA PRO_100 printer and I did not use it for about six months. Recently I tried to make some photos prints and had bad results. I did a deep cleaning on the maintenance program several times with no success. I took out the printer and cleaned it and got similar results. So I assumed it was the printer head that was giving problems. I bought a new one and installed it, got the same results. When I print a copy of the test after deep cleaning only one of the two groups colors are printing, nothing on group 2...i.e. Cyan, Black, Light Grey and Grey. The inks are all filled and the they are all lit up in the printer head. Can you kindly assist me ?
Regards,
Albert
12-02-2015 11:07 PM
Are the inks new as well? If you touch the sponge at bottom of cartridge does your finger get ink on it?
12-03-2015 09:51 AM
12-03-2015 09:53 AM - edited 12-03-2015 09:55 AM
Call or email the Canon support line. I have always found them very helpful. See second entry.
12-03-2015 09:55 AM
That I will do... thanks again
12-03-2015 10:25 AM
"I took out the printer and cleaned it ..."
Whoa!
How did you "clean" it? This is something you can screw up pretty easily.
You might try a reinstall of the software and drivers. It is possible you added some new software that interfered with it.
Completely remove the old driver first, however.
12-03-2015 10:38 AM
Hi ebiggs1, I was very careful with the process of cleaning the printer head. However, after going through that process, I bought a new printer head and carefully installed it and got the same results. I will try your suggestion and reinstall the software after removing the existing version. Thanks.....
