Reply
Honored Contributor
Re: Pixma Pro-100 Color Matching on iPad Pro
Here is where you would adjust image size in LR.
1D X Mark III, Many lenses, Pixma PRO-100, MX472, LR Classic
Honored Contributor
[ Edited ]
@LaurenN wrote:
These is the only Canon showing up.  Do I need to download a different driver?
Yes. Go here and download the 1.06 version driver.
https://www.usa.canon.com/internet/portal/us/home/support/details/professional-large-format-printers...
Turn off printer and unplug USB first.
Occasional Contributor
Those changes worked...I now have the correct driver and set everything up the way you suggested.  Should I be printing the calibration page again?
Honored Contributor
Yes. Before you do that go back to Devices & Printers and right-click on the WS printer icon and delete it.
Then print the test image and see what you get.
THAT WORKED. I want to eat the strawberries.  Smiley Happy
Now how do I get that to match with the drawings from the iPAD??
Thank you for working through this with me!!
Honored Contributor
Try exporting your iPad document as a PDF and then print it from Adobe Acrobat Reader on your PC.
Also, now that you are getting a good print adjust your laptop display, particularly brightness, to match print.
Hi John,
We made the image a PDF and printed through Adobe Acrobat Reader, but the colors still don't match when they print, although they looked spot on in Reader.  I also tried to adjust the settings through the Color Management options, but they all seem to be in order.  I think part of the problem might be that with a laptop, when you change the angle of the screen, everything looks different, so I am not able to really tell if the settings are accurate. The brightness is set to its highest setting, which seems tolook best, but...?!  I feel like I've followed all of the steps and am still coming up short, but I'm sure I'm missing something.  Smiley Frustrated  Any other tips?  Thanks again.
Honored Contributor
I don’t have any suggestions. I don’t print from Acrobat often and when I do it’s documents.
Are there any other settings in Lightroom that I can change to get it to print correctly?
Honored Contributor
Does this help?
https://kent.teamdynamix.com/TDClient/2005/Portal/KB/ArticleDet?ID=63342
powered by Lithium
