09-29-2015 07:43 PM
Finally got a stable enough set of time to get out my printer and do some printing only to find it prints 2-3 inks of 10.
I also find installing the drivers on Windows 10 hangs (cant discover the printer, although when it was plugged into the USB, Windows found it no problem). Thus making it a challenge to use the maintenance program.
Do I just need to replace the cartridges or is it FUBAR?
Thanks gang,
Reid
10-01-2015 10:11 AM
I didn't plug the USB in until prompted during the software install. It's the 2.7 driver. so it had not been discovered yet.
10-01-2015 10:22 AM - edited 10-01-2015 10:22 AM
Give the Canon help line a call. I have always found them responsive and helpful. They can sort out the driver install problem.
10-03-2015 08:29 AM
Success. Soaking the head in warm water 1/2" deep and then replacing the cartridges did the trick.
Meanwhile, I scored a NEW IN BOX Mark II 9500 for the cost of cartridges and print head...so all in all, I now have 2 great printers, the new one will sit in the closet in the box until I need the parts
Thanks gang
10-03-2015 08:33 AM
10-03-2015 09:54 AM
So now I'm getting "Start after opening the image you want to print" when I go to start PSPro...
10-03-2015 11:02 AM
Not sure I fully understand what you meant to say, but you do need to have an image selected in PS or LR before you select PSP.
10-03-2015 11:12 AM
Again figured this one out shortly after. I went to the EOS 60D downloads found the full install of PS and that solved the problem. The PSP install on the printer driver page wasn't complete
