09-04-2019 05:11 AM
Hello,
My PRO-2000 has started leaking ink onto the edge of prints - see image below.
i'm considering changing the print head but am worried that this might just be a waste of £500 - the dot count of the current head is less than half of the previous head when that was changed (prompted by the printer to change, there are no error messages with the current fault).
Do you think it's the head that is the problem?
Thanks for any help.
Frank.
09-06-2019 03:38 AM
I replaced the PF-10 print head.
I've attached a photo of the faulty old one below - you can see the leak of magenta ink.
According to the print head dot count I've had less than half the expected use from this head before it developed the fault (and it lasted 10.5 months). Are the heads covered by a warranty? Any help much appreciated.
09-06-2019 08:37 AM
Hi, Frank!
Thanks for posting on our forum! This community is designed for your fellow Canon owners to help each other out with any problems they may encounter. If this is a time-sensitive matter, click HERE search our knowledge base or find additional support options HERE.
Thanks and have a great day!
