01-02-2021
02:33 PM
11:47 AM
Hi all,
I am having issue printing with my Pixma Pro-200. I am now getting an error message on the "Professional Print & Layout Job Manager" that says "ERROR- Please check the printers operation or the remote UI".
I have tried uninstalling the printer and all software from my MAC and reinsttalling but to no luck.
The printer is listed on settings under printers and says that it is idle, ready to be used. I was able to print a test page.
I am trying to print a photo from the "Professional Print & Layout" software and that seems to be the issue.
any adivse?
01-02-2021 06:49 PM
Welcome to the forum.
This may not be your problem, but frequently when folks haave Canon printer proms on a Mac it is because when they added the printer they wound up with the AirPrint version of the printer.When the Add Printer "+" icon is selected the first item that appears is the AirPrint version of the printer.
Check in the Printers&Scanners option and see if your printer is labeled "IJ Series". If not, select Add again and wait for the IJ Series to appear; it could take several minutes.
11-07-2023 11:42 AM
I have the same problem. I deleted the printer labeled AirPrint and reinstalled. However, there are no choices for IJ or AirPrint in Sonoma 14.0. Canon Easy Pro Print Editor works fine, but it has fewer options. Any suggestions are most welcome. Thank you.
11-07-2023 12:09 PM
Are you using the Apple AirPrint driver inadvertently?
11-07-2023 03:35 PM
I haven't a clue, John. How do I find out? The computer is brand new and I just copied everything from the old one. Professional Print & etc. didn't work on the old one either.
03-06-2025 11:29 AM
I know this thread is a couple years old, but I had the same issue and discovered this blog post. Happy to report that it worked...at least for now. https://www.freestylephoto.com/blog?p=canon-professional-print-layout-remote-u&srsltid=AfmBOoqJS1HlQ...
