PIXMA PRO-200 - printing GREEN
EliseM
My printer has started printing everytihg with a heavy green hue.  When I run a print test or color block test it prints beautifully.  I have printed several different files and files types and media types and they all come out with a green hue. We have even sent the files from various programs and computers with no change.   All my inks are full and in the right slots. We checked and we don't have any clogged nozzels and we are current on firmwear updates.  What could be causing this?  How can I fix it?
15 REPLIES 15
Welcome to the Canon Forums!
The Forums aren't intended for immediate assistance. If your question is of an urgent nature,click HERE to visit your My Canon Account to discover your personalized support options.
If you're outside of the USA, please click HERE to find your support options.
SKM35938
I'm experiencing the same issue. I have tried everything, including several deep cleanings of my nozzles. It's super frustrating. I am using the Canon Professional Print and Layout, and I have somewhat solved the issue by overcompensating the Magenta by +45 and that seems to work but images in the Professional Print & Layout looks insane when I do this. So it's not a clogged nozzle because if that were the case, then I would get the same amount of magenta when I overcompensate. Is this a software issue? I have reinstalled drivers & firmware as well. I'm using the correct color profile and paper profile as well. Screenshot 2025-01-06 at 7.27.31 PM.png
latteeiffel
I’ve seen my printer for inspection in Hong Kong and canon said I was using another brand of ink so probably it’s one of the substitute colour is off. He told me when he use Canon ink it prints out perfectly… so I’m guessing maybe stick to the original brand though it’s more expensive. My guessing is the M or PM ink is off and not the green is not caused by the cyan but lack of M or PM. So by adding more M to the print you offset the colors to correct one…
SKM35938
It sounds like your Canon Pixma Pro 200 is experiencing a color management issue rather than a hardware problem, especially since test prints look fine. Here are a few things to check and adjust to resolve the green tint:
1. Check Color Management Settings:
  • In your printing software (Photoshop, Lightroom, etc.), ensure that Color Management is set to "Photoshop Manages Colors" (or similar).
  • In the printer driver settings, set Color Correction to None or "Off" to prevent double color profiling.
2. Use the Correct ICC Profiles:
  • Make sure you're selecting the correct ICC profile for the paper you're using. If the wrong profile is selected, it can result in color shifts.
  • If you're using third-party paper, download the ICC profiles from the manufacturer.
3. Update and Reinstall Printer Driver:
  • Uninstall the current printer driver and download the latest version from Canon’s website. A corrupted driver could cause color output issues.
4. Disable "Print Preview" in Printer Driver (Windows):
  • Sometimes the "Print Preview" option can affect the final print output. Disable it and print directly.
5. Check for Software Conflicts:
  • Print from a different application or device. If the issue persists across all programs, the problem is likely with the printer driver or color profile settings.
  • Test print from Canon’s Print Studio Pro plugin if available.
6. Perform a Printer Reset:
  • Perform a factory reset on your printer by going to the printer’s settings. This can clear any lingering configuration issues.
7. Print in Grayscale (as a Test):
  • Try printing in grayscale or black and white. If this prints without a green hue, the issue is isolated to the color management settings rather than the ink system.
To reset your Canon Pixma Pro 200 printer to factory settings, follow these steps:
Resetting to Factory Settings:
  1. Turn on the Printer:
    Make sure your printer is powered on.
  2. Access the Menu:
    • Press the Setup button on the printer's control panel (it looks like a wrench or gear icon).
  3. Navigate to Reset Settings:
    • Use the arrow buttons to scroll through the menu options.
    • Look for Device settings and press OK.
    • Scroll down to Reset settings and press OK.
  4. Choose Reset Option:
    • Select Reset all to return the printer to factory default settings.
    • You may also see options like LAN settings only or Settings only – choose Reset all for a full reset.
  5. Confirm the Reset:
    • Press Yes to confirm the reset when prompted.
  6. Restart the Printer:
    • The printer will reboot and restore to default settings.
After resetting, reconfigure your printer, reconnect it to your network, and reinstall drivers if necessary. This should help clear up any configuration issues.
SKM35938
It's the ink. Make sure you're not using a knockoff ink from Amazon. I had the same issue, so I ordered some Canon ink, and it prints perfectly now.
