04-25-2024
01:08 PM
08:11 AM
James_C
My printer has started printing everytihg with a heavy green hue. When I run a print test or color block test it prints beautifully. I have printed several different files and files types and media types and they all come out with a green hue. We have even sent the files from various programs and computers with no change. All my inks are full and in the right slots. We checked and we don't have any clogged nozzels and we are current on firmwear updates. What could be causing this? How can I fix it?
12-23-2024 09:39 PM
I just bought this printer and now I'm having the same issue. I had my printer onsite at an event and it put me in a VERY BAD SITUATION. I had to adjust the colors within LrC to compensate (spelling) for the green tint. Had anyone fould the solution for this yet? JBaker
01-06-2025 08:29 PM
I'm experiencing the same issue. I have tried everything, including several deep cleanings of my nozzles. It's super frustrating. I am using the Canon Professional Print and Layout, and I have somewhat solved the issue by overcompensating the Magenta by +45 and that seems to work but images in the Professional Print & Layout looks insane when I do this. So it's not a clogged nozzle because if that were the case, then I would get the same amount of magenta when I overcompensate. Is this a software issue? I have reinstalled drivers & firmware as well. I'm using the correct color profile and paper profile as well.
01-06-2025 10:17 PM
I’ve seen my printer for inspection in Hong Kong and canon said I was using another brand of ink so probably it’s one of the substitute colour is off. He told me when he use Canon ink it prints out perfectly… so I’m guessing maybe stick to the original brand though it’s more expensive. My guessing is the M or PM ink is off and not the green is not caused by the cyan but lack of M or PM. So by adding more M to the print you offset the colors to correct one…
01-07-2025 10:53 PM
It sounds like your Canon Pixma Pro 200 is experiencing a color management issue rather than a hardware problem, especially since test prints look fine. Here are a few things to check and adjust to resolve the green tint:
01-07-2025 10:55 PM
To reset your Canon Pixma Pro 200 printer to factory settings, follow these steps:
Turn on the Printer:
Make sure your printer is powered on.
Access the Menu:
Navigate to Reset Settings:
Choose Reset Option:
Confirm the Reset:
Restart the Printer:
After resetting, reconfigure your printer, reconnect it to your network, and reinstall drivers if necessary. This should help clear up any configuration issues.
01-09-2025 10:28 PM
It's the ink. Make sure you're not using a knockoff ink from Amazon. I had the same issue, so I ordered some Canon ink, and it prints perfectly now.
