11-10-2025 10:53 AM
Hello, i have been experiencing an issue with my PIXMA PRO 200 where it pulls multiple sheets at a time. This issue is new and never use to happen. Not sure if something broke, it seems there might be a piece of plastic bent near the feed. I've attached a photo of the paper feed for reference to see if anything looks off to anyone. Thanks in advance for your time.IMG_9563.jpeg
11-10-2025 12:59 PM
Greetings ,
It may be difficult for us to see any anomalies from the image with perspective.
Have you tried a different brand of paper? Try loading no more than 8 to 10 sheets and see if the behavior continues. It's important to fan paper before you load it. Also make sure that there's not excess humidity. This can cause binding.
Check to make sure the rollers are clean. You can use Q-tips lightly dipped in alcohol to keep things clean
