04-12-2025 06:58 PM
I just received a Pro-310 and have it setup and printing from my MacBook Pro running Sequoia 15.4.
I can't seem to get full control of the print driver and color. I print from Lightroom Classic and can't control the optimizer or insure that the color is being managed by the software and ICC profile. The paper is Canon Pro Platinum.
Any suggestions would be appreciated.
04-13-2025 06:40 AM - edited 04-13-2025 06:41 AM
Verify that when the printer was added you selected the Canon IJ Series version and not the AirPrint version. What you are describing is typical of using the AirPrint driver.
04-13-2025 08:59 AM
Just checked and the driver is the AirPrint driver. I need to download the IJ version and try it.
04-13-2025 09:24 AM
Yes. When you go to add printer wait, could be several minutes, for the IJ Series driver to appear. Once you are all set delete the AirPrint version of the printer.
04-13-2025 09:28 AM
The driver no longer says "AirPrint"; it now says:
Canon PRO-310 series
Version 29.5.0.0
04-13-2025 09:29 AM
That is what you want. Delete AirPrint version of printer if it is showing.
04-13-2025 09:32 AM
Yes, I deleted the AirPrint driver.
Thanks for your help.
