Horizontal lines on print Canon Pro 1000
ERMU
beginning of printbeginning of printend of printend of printbeginning of printbeginning of print
When I print on format A2 I get horizontal lines at the beginning and end of the print, the first and last 5 cm of the print, see photos. In between the print is perfect. The paper I use is Canson Baryta photographique II 310 g/m2 and totally flat before use. Nozzle check pattern is OK, prevent paper abrasion is on, vacuum by default is on.
Does anyone have an idea what it could be?
15 REPLIES 15
themagiceight— –
Yes I recognized that after I posted my photo of my symptoms.
Mine is a sort of fading away of *some* of the inks,
in a soft-edged band running parallel to the movement of the print head,
starting about 8 cm from the edge of the A3+ sheet of semi-gloss paper.
I should perhaps start a new query thread for what i am seeing.
thank you
MichalMazur
How is the situation here?
I and many others experience very similar problems with pro 1100. Canon already replaced many units and all experience the same problems. I just got my replacement and I’m so devastated.
"Pause between scans" seems to be the relevant setting. At 5 seconds, I don't get horizontal lines. Of course, this is a disappointing fix since it massively increases print time.
My guess is there's a design flaw in the pro 1100 and all units are affected more or less to the same extent. I'm on printer #3 after two RMAs -- they all do it
MichalMazur
Thank you very much. Based on the description of this function I have no idea how this influences that type of banding but... I gave it a try and it actually worked. It was late, so I just tested 2 prints but I will test more today.
Fortunately I'm home/hobbyist photographer and I do not need to print some number of prints in specific period of time but it might really be a killer for professionals.
faneuil
Last night - while reviewing the service manual - I discovered the existence of the "timing slit disk"
Over the years, overspray of ink had gotten all over mine. Several cleanings with q-tips, pads and windex fixed it
Did a recalibration of line-feed (in the media config tool) and banding was GONE!Screenshot 2025-08-21 at 5.49.51 PM.png
faneuil
This celluloid-like calibration disk had huge clots of ink on it.
Which explained why the line feed banding was occurring in regular intervals - as the obscured portions passed under the sensor, the printer could not calibrate it's feed
Fortunately, I did not have to take the printer that much "apart" - Just the left side panel and I could access the disk via port holes with swabs (I used lens sensor swaps soaked in windex) on both sides of the disk
