03-12-2019 09:00 AM
I've been pulling my hair out. I have Spyder screen and print calibration - I've gone through all the steps dozens of times.
I've printed targets, I've read targets, I've used every Media Setting in combinations.
I can get almost spot on color with color photos.
The Heavy Weight Fine Art settings (based on a target made that way) is a bit washed out.
The Matte Photo Paper is over saturated, or tinted on way or the other.
I make adjustments to the profile, and I can get by.
Then I go to print a grayscale image using these profiles and instead of a neutral image I get pink or magenta.
All this is through Canon Print Studio Pro working withing Photoshop 2019.
I'm about to give up and build a darkroom.
Any similar experiences, or hints?
03-12-2019 03:00 PM
Have you tried using the profiles supplied by Hahnemuehle? I use their profiles with several of their papers with good results.
03-12-2019 03:06 PM
03-12-2019 03:06 PM
03-12-2019 03:18 PM
What Hahn papers are you using, and what printer?
03-12-2019 03:27 PM
03-12-2019 03:49 PM
I don"t use those papers, so I can't report my experience.
03-12-2019 11:21 PM
I use the Hahnemuhle Photo Rag on my Imageprograf PRO-4000 with great results. Try setting the printer driver to "Highest Density Fine Art Paper." I got that from this document:
https://support.usa.canon.com/kb/index?page=content&id=ART163327
There's also this document:
https://ugp01.c-ij.com/ij/webmanual/Manual/All/PRO-4000/EN/PIF/pif_4000f_0000_2ra_eng.html
It also shows settings for Photo Rag. I print straight from Photoshop or Illustrator; I don't use Print Studio Pro. Be sure you're setting the right paper profile under "Color Management" in the Photoshop dialog box, and then the same paper type when you go into Print Settings and enter the paper type in Canon's print driver. If both papers don't match, you won't get good results. Let me know how it goes.
Neil Goldman
Indigo Image Lab, Inc.
03-12-2019 11:47 PM
Thanks Neil,
That's encouraging.
I will look at all those options.
I may be having a hardware problem.
I keep having to clean the Yellow head, it keeps getting clogged.
I wonder if I'm getting strange colors ...
But I'm really trying to figure this out, and I'll update the post.
Elias
03-13-2019 09:15 AM
Now I'm finding that the Canon Pro-1000 won't take files from PS. It will only go through Print Studio.
I happened to find another post of yours Niel where you were having similar trouble printig from PS.
I'm going to uninstall the printer, reload the driver, and try again.
What an expensive machine to get on-line!
