05-02-2013 05:24 AM
I have a Pixma Pro-100. Under what circumstances would I print in “grayscale”?
05-05-2013 08:18 PM
Hello Tinman.
When the "Black and White Photo Print" is checked and the printout begins, the document is converted to grayscale data. This option allows you to print color items in monochrome. The black and gray tanks would primarily be used when this option is selected.
05-02-2013 10:22 AM
To set-up your monitor!![]()
05-02-2013 10:30 AM
“To set-up your monitor!”
What does that mean? If there are three monochrome inks, is there a need to print in “grayscale”.
05-02-2013 11:53 AM
A gray scale can be helpful in matching your monitor to your printer. If your monitor does not show you what your printer is going to print, you are wasting time and materials.
You can hold up the sheet of gray scale print out right up next to the monitor and make a good comparison. Some people do this better than trying to match colors.
05-02-2013 01:38 PM
I understand what you are saying but I think that I am asking a somewhat different question.
I thought that “Grayscale” printing involved blending the color ink to arrive at different shades of grays. The Pro-100 has three monochrome inks, which should print in various shades of gray. Under these conditions, when (if ever) should grayscale printing be used? When I check the ”Print Black & White photo” box is that the same as printing in “grayscale”?
05-05-2013 08:18 PM
Hello Tinman.
05-05-2013 10:29 PM
Michael:
Thanks for the answer.
