Error E161-4050
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report Inappropriate Content
11-08-2012 08:56 AM
I was setting up my brand new IPF 6450 last night and during the initial ink charging process, I received an Error E161-4050 message and cannot do anything else. It was after hours so I couldn't call Canon. I send an email to tech support but haven't heard back.
Has this happened to anyone or does anyone know what the cause might be?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
10-10-2013 06:44 PM
There is no such an error in the service manual. At least mine did not have it. But it looks like related to an ink supply to a printhead. I would try to launch '' ink tube replacement procedure''
Most wide format Canons programmed this way.
Start machine. As soon as you see carriage moved out of it's home position , unplug it. (I mean unplug it , do not use soft button on the control panel)
It will leave carriage unlocked. Move carriage out by hand, remove print head. close everything back.
Remove all ink cartridges. Start the printer. And then just follow instructions on the display.This way you can drive ink into the printhead strongest way that is available. Printhead cleaning only 30% of the suction power compaire to this method.
Good luck.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
10-10-2013 06:49 PM
P.S . If this doesn't help. There is a problem with the purge unit.And it has to be replaced.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
12-19-2019 01:38 PM
I have iPf-5100. When the cleaning cycle reaches 50%, the error E161-4050 appears. I have tried printing a test page on a roll media in service mode but receive the error that the paper is jammed. If I try sheet-feeding the paper, the message says to reload the paper.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
12-20-2019 10:57 AM - edited 12-20-2019 11:00 AM
Hi . This error means that printer did not detect Ink coming out of the printhead during installation or during print head replacement.
If your machine is brand new following can cause this problem: If ink tubes filled up with the ink , then eiter print head is faulty (which is quite common ) or nozlle check position adjustment is not performed. So nozzle discharging ink missing print head management sensor.If some ink tubes are not filled up with the ink or have air pocket , then it means you have faulty purge unit or nozzle positioning is not adjusted or both.
Regards,
Spectator
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
12-20-2019 01:53 PM
Thanks for your response. The machine has been used successfully for some time. Your response leads to another question. How does one detect air bubbles in the ink line? My lines do not seem to be transparent. Is there a procedure whereby one can remove the ink and bubbles and then refil again? Also, if the nozzle is not positioned correctly, how does one position it correctly?
Regards,
Dhump
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
12-20-2019 03:24 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
12-20-2019 03:44 PM
Spectator:
Thanks. I will try the nozzle check although i think I have tried that and I received a paper jam error. I will try again.
Regards,
Dhump
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
12-26-2019 01:16 PM
What with Holiday guests, I have not had time to work on the problem. Today I began to try diagnostic suggestions.
I am unable to see any air bubbles in ink lines. It appears that I have another problem. When I try to run a nozzle check using roll paper, I receive a "Paper Jam" error. the paper appears to be straight coming off the roll and it sits nicely against the guides. When I try to run a nozzle check using manual feed using 13 x 19 sheet, I receive a "Paper Please Reload, Size Undetected". I have previously chosen the 13 x 19 size. As near as I can tell, there does not seem to be any paper scraps, etc in the paper way.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
12-26-2019 03:24 PM
Give Canon a call at 1-800-OK-CANON.
