01-10-2015 08:01 PM
I am trying to print a custom paper size and for some reason the "Custom" option on my drop down menu is blacked out. Does anyone know how I am able to get that to work again so I can eneter a custom width and height? I have attached a screen shot to show what I mean.
Thank you!
Jillian
01-10-2015 08:21 PM
Hello jilliank!
Welcome to the Canon Forums, and thanks for your post!
To have a better understanding of your issue, please let everyone know what operating system (Windows Vista/7/8 or Mac OS 10.X) you are using and if you are connected via USB or WI-FI. That way, the community will be able to assist you with suggestions appropriate for your product.
If this is a time-sensitive matter, our US-based technical support team is standing by, ready to help 24/7 via Email at http://bit.ly/EmailCanon or by phone at 1-800-OK-CANON (1-800-652-2666) weekdays between 10 AM and 10 PM ET (7 AM to 7 PM PT).
Thanks!
01-10-2015 08:23 PM
I am using Mac OSX 10.10 and I am connected via USB. Every other size option from the drop down menu appears, except for "Custom". Just not sure why.
Thank you in advance!
01-10-2015 09:43 PM
What happens if you click on the defined by driver option?
01-11-2015 09:50 AM
Did that ever work?
The best and by far the easiest way to do custom print sizes is to use standard paper and buy a paper trimmer. One advantage is you may be able to put multiple images on a single page and trim them down to the required size.
Like wallets for instance. I do that all the time.
