Combination of Maxify MB5420 and PIXMA PRO-100 drivers causes "filter failed" on PRO-100 print job.
kbcons
Mods, please note that I will be cross-posting this to the Office Printers forum.
There are several Canon printers here; the above mentioned MB5420 and PRO-100 as well as an MF249dw.
Conditions:
Mac Mini late 2012, 16GB memory, 500GB SSD, i7, Catalina (updated current as of 9/11/2020)
Canon Maxify MB5420 (Current as of 9/12/2020)
Canon PIXMA PRO-100 (Current as of 9/12/2020)
Canon ImageCLASS MF249dw (Current as of 9/12/2020)
All the above devices are connected via Ethernet, with static mapped IP addresses.
Observation:
Driver installations appeared to be completely normal using "Canon Inkjet Network" for the MB5420 and the PRO-100.
When the CUPS print drivers for all the above printers are installed, I am unable to print to the PRO-100. "Filter failed" error message. When I remove the drivers for the MB5420, print jobs for the PRO-100 are processed normally. The presense of the MF249dw driver has no effect on the PRO-100. The presense of scanner drivers for the MB5420 has no effect on the PRO-100. Printing to any of these devices from a Windows 10 Pro machine is normal with all drivers installed.
Desired endgame:
I would prefer to have the MB5420 available to me as the default printer for everyday use.
Ideas?
Ken...
Patrick
Hi kbcons,
Please follow these steps:
 1.  Click on the Apple in the upper left corner and then System Preferences.
 2.  In System Preferences, click on Printers & Scanners.
 3.  On the left side, please click on the MB5420 one time and then [-] at the bottom to remove it.
 4.  Click on the [+] and then "add printer or scanner".  The Add window will appear.
 5.  In the Add window, please click one time on the MB5420 - Bonjour multifunction that appears.
 6.  At the bottom, next to "Use", please select "Airprint".
 7.  Click Add.
Does the issue persist?
2 REPLIES 2
Patrick
Hi kbcons,
 7.  Click Add.
The issue appears to be resolved - soft of. Printing to the PRO-100 is slower than before.  Printing to the MB5420 seems normal, and I'm hoping that I will have full functionality with the Airprint driver.
Clearly, this is a work-around and I'd prefer an actual fix.  Hopefully, this actual fix will come in a driver update.
Thank you,
Ken...
