10-09-2016 11:56 PM
Hi All,
Has anyone heard of an update for Canon drivers, specifically for the Canon Pro-1000, that works with macOS Sierra? I'm trying to print the first of two target sheets using a ColorMunki Photo but page comes out distorted & printer fails halfway through the page. After contacting X-rite, they replicated the problem, & have advised me it is a Canon driver problem with Apple's new OS.
Does anyone know of a workaround with ColorMunki Photo? I can't really do much without being able to calibrate my printer!
I do find it crazy that Canon had 6 months to work on drivers before Sierra came out, especially recently having brought onto the market a new pro printer that now can't even get calibrated.
I'm on the latest Canon Pro-1000 firmware 2.02.0.
Appreciate any thoughts. Thanks.
10-10-2016 07:05 AM
Go to the Canon support page.
10-10-2016 07:51 AM
10-11-2016 10:01 AM
Found this:
https://support.usa.canon.com/kb/index?page=content&id=ART166610
10-11-2016 08:12 PM - edited 10-11-2016 08:15 PM
Thanks again John. That is a good work around for general printing needs.
My specific problem at the moment is trying to print the first of two colour target sheets in order to calibrate my Canon Pro-1000 with ColorMunki Photo. The CP software doesn't allow any diversions, meaning you have to comply with each step of the process. It isn't possible to change any printing options, such as converting to pdf or tiff.
When i get to the stage of printing out the first test sheet the printer fails with the error "Filter failed". I don't really know what that means except that the printer's output is distorted & stops about a third down the page, as below. This happens every time I attempt the process.
X-rite has confirmed that it is a Canon printer driver issue with Sierra & i think they are right as Canon has itself notified that they have an issue. I gather once Canon resolves the driver problem, the ColorMunki issue will also resolve. Of course that doesn't help me right now trying to calibrate a new printer..
I appreciate your interest in helping me with this issue.
Cheers!
