04-17-2018 09:11 PM
Prints from Canon Pixma Pro100 on the Hahnemuhle Photo Rag Baryta paper are coming as slightly skewed. I am printing on a 13x19 paper, and the following were the settings:
Image Size: 12x15
Top margin: 0.476
Bottom Margin: 0.476
Left: 2.008
Right: 2.008
However, when the print finally came out the top margin was not consistent. The top right margin was 0.476, but the top left was 0.3. On a 19 inch long paper, the difference was really visible. I have tried many forums but there was not a solution in any forum. I am attaching a photo of the print, which would explain the problem.
04-17-2018 10:46 PM
Try a roller cleaning.
04-18-2018 04:07 AM
I am sorry, but I do not understand. What does roller cleaning have to do with margins being off?
04-18-2018 07:09 AM - edited 04-18-2018 09:11 AM
If the rollers are not feeding the paper evenly the paper could be skewed as the print is being made.
I printed a test image. I don't have the rag paper but I used silk Baryta. Used these settings:
Printed fine.
Does your problem happen consistently or just once? WiFi connection or USB?
04-18-2018 01:23 PM
I am cleaning my manual roller and will check again. I didn't face this problem before. This has been coming since I started using the A3 size PhotoRag Baryta paper. I suppose it is only happening in this paper.
I am using Wifi to take prints. Does that affect in any way?
04-18-2018 01:33 PM
Some people have reported printing issues with wifi; maybe weak signal. I have never seen it first hand.
Another thing I have read is some papers have processsi ng dust on them and that can cause slippage.
Is your print rectangular but rotated or are three sides parallel to edge and one with wrong margins?
04-18-2018 01:54 PM
My print is rectangular, but it's NOT parallel to the longer edges of the paper. The top left margin < top right margin. Similarly bottom left margin > bottom right margin.
04-18-2018 01:56 PM
OK. Definitely sounds like it is not feeding properly. Roller cleaning might help. Were you feeding from manual feed tray? Guides closed in against paper?
04-18-2018 02:02 PM
Yes. I was feeding on the manual tray, and as far as I know, I closed the guides properly. I have performed manual roller cleaning and will try to take a print again. I will keep you posted.
Thanks!
04-19-2018 12:53 PM
It was definitely a paper feeding issue. I was feeding the paper correctly but since my paper is quite heavy when the roller pulls it in, it moves a bit and I had to again set the guidelines. Once I did that the print came out correctly.
For others, while feeding a heavy paper keep an eye on the paper going in from the manual feeder and correct it if it gets off the guidelines.
Thanks for your help!
