05-27-2020 08:28 PM
When I try to print brown, it comes out purple. When I print the nozzle check maintenance page, the yellow portion of the page is instead light brown. I did just put in a new yellow cartridge (among others), so I dont want to replace it unless there is no other option.
Why are the colors off so much?
05-28-2020 08:49 AM - edited 05-28-2020 09:47 AM
Welcome to the forum tunglashr.
Try unseating and reseating the cartridges. Verify that all the clear tape has been removed from top of cartridges.
Is this a new printer? Did it work OK before you installed the new yellow cartridge?
Are you using Canon inks?
Did you try a head cleaing?
05-28-2020 11:04 AM
I have already reseated all cartridges and remvoed all tape. The issue persisted. This is not a new printer, it had been working well before this.
I dont know the brand of the inks, I got them from Amazon.
How do I do head cleaning?
05-28-2020 11:27 AM
One the same maintenance page as the nozzle check.
05-28-2020 11:35 AM
I see cleaning, deep cleaning and print head alignment. Which of these is the one I need to do? Also, it says that it consumes ink, does that mean it uses all remaining ink, or just that it uses some?
05-28-2020 11:38 AM
05-28-2020 02:23 PM
The cleaning seemed to have worked. Colors look a lot better now.
Thanks
