05-08-2023
12:13 PM
09:27 AM
So, click Print
Select Canon Pixma Pro 100S series
Click More Settings
Select Media Type as Other->Printable CD (shows after OK as "Printable disc (others))
Select Printer Paper SIze as "Disc tray K"
Select Paper Source as "Disc tray"
Click OK
Click Print
Quick printing dialog flashes up, then:
Dialog box:
"Support Code 1006"
"Paper has run out"
"Media type: Photo paper Pro Platinum" (I selected printable disc as described above)
"Page size A4" (I selected Disc tray K as above)
"Load apper into manual tray" (I told it to use printable disc in tray K)
"Load a sheet of paper into manual feed tray" (I said I wanted disc tray)
What gives? Why does the driver ignore every setting I give it and insist on trying to print on A3+ Glossy from the rear tray?
Can it be fixed?
Nick
